1 members (Rusty Rod), 105 guests, and 2 robots.
Topics128,026
Posts1,055,404
Members48,422
#779864 09/11/2011 6:35 PM
Can anyone tell me where is a good source for valves and guides for my 1957 270? I have tried multiple sources in the "links" section but so far have come up empty. Had a problem with the Egge link.
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Look at the Egge Site. http://www.egge.com/ and click engine kits. Scroll down to GMC, engine kits and click what is in the kit. They are not cheap. I see NOS GMC valves on eBay quite often. Valve guides appear occasionally. You need to be really careful when installing the guides and valves. Quite often you wind up with too little stem clearance and the valves will hang open. I always ream them to the looser end of the specs. That way I don't worry about them seizing.
