6 members (32Fordpuchoptop, Youngin' Tut 59, treegrower, Gray_Ghost, Wickedbass, WICruiser), 66 guests, and 3 robots.
Topics128,076
Posts1,055,922
Members48,430
#779494 09/10/2011 12:35 AM
1957 stock truck radio (tubes).
Can I get some direction on what amp fuse to use on connecting this to the battery for power?
Darling #779510 09/10/2011 1:38 AM
7.5 amp recommended 10 amp max, connect from a switched circuit so it goes off with the key, usually the fuse panel if you have one ... also find the manual here
squeeze #779598 09/10/2011 9:41 AM
Thanks, Bill
