1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | 1957 stock truck radio (tubes).
Can I get some direction on what amp fuse to use on connecting this to the battery for power? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 7.5 amp recommended 10 amp max, connect from a switched circuit so it goes off with the key, usually the fuse panel if you have one ... also find the manual hereBill | | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | | | |
