7 members (Brian Moore, MickeyP, Gdads51, Wayne67vert, Bill Hanlon, Woodcmiami, Ridgeback), 63 guests, and 2 robots.
Topics128,049
Posts1,055,653
#775580 08/27/2011 6:57 PM
I have a stock 63 C10 with the 283 V8 and 3 spd manual. I am replacing the oil pan gasket. Since I made it that far, I am wondering if I should go ahead and change the rear main seal. Although I have never done that job, it looks simple enough in the shop manual.
I don't believe the rear main seal is leaking. Don't see any oil on the flywheel or clutch. So question is, is it worthwhile to go ahead and change the rear main seal since I am so close and its only $15 for the seal, or should I leave well enough alone?
Riding in the Passing Lane
Myself I would leave it alone if its not leaking. If you change oil regularly it will probably last a long time.
1972 Chevy c10 Cheyenne Super
Certified Bolt Nut
Certified Bolt Nut
If it were me I would go ahead and change it out. The way my luck goes it would start leaking next month.
I agree w/sixtyfive c-10, i think I'd replace it with the way my luck goes.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
If it ain't broke don't fix it.
The way my luck goes I'd replace it and then the seal wouldn't seat quite perfectly and start leaking. Then I'd have to pull the pan again and fight to get all that fresh gasket material off, not get it all completly off and have a leak at the pan. By the time I've had the pan down for the 3rd time I'd be so [censored] I'd forget where I put the bolts and have to run to the store and get replacements where upon returning home I'd see the pile of bolts sitting right there under the truck.........
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
If you are there replace the seal.
I decided to leave it in. We'll see how my luck holds out. Changing the pan gasket wasn't as hard as I expected, so if the seal does start leaking, I can get 'er done.
Thanks for the advice.
