Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (oldieoldie, texas46, frogfarmer), 206 guests, and 1 robot.
Topics128,299
Posts1,058,705
Members48,493
#761468 07/11/2011 2:51 PM
Y
Y Offline
I recently was promoted and transferred to Ohio. I have been waiting to move all of my bolt's to Ohio until the Kansas house sells so that I can use the extra money to build a barn for the bolts to reside in. So for this summer's vacation I am back in Kansas working on the bolts and spending some time driving them. Of course if you see the Weather Channel you will notice that Kansas, particularly northeast kansas has been steady at 100'F plus. So I have been enjoying the shade of the area under my 4400 servicing the brakes. I was not sure what to expect because I could add fluid and bleed, but I would lose all of the fluid in a matter of hours. Turns out the driver's side rear cylinder seals are shot, but the others are not bad. For good measure I have been rebuilding each of them since rebuild kits are cheap, and my FLAPS stocks them. My 4400 is a grain truck, so there is plenty of shade from the wood bedsides. I probably will only nurse it around because some of the tires are in need of replacement. I also worked on the original self cancelling turn signal set and got them working. I am going to investigate tires at the local COOP machine shop. they put some new tires on my brothers 3800(7.00 X 18) fairly reasonably. I will post the part numbers tonight for the wheel cylinder kits. I have also cleaned and repacked the wheel bearings since I had the hubs apart.
Thought I would share. I love to drive these trucks. I will post some pics tomorrow. I will also say that I can see why the triangle vent windows are so popular. My brother has them in his 53 3800. they really make the cab breathe.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
Y
Y Offline
Was able to get all the wheel cylinders rebuilt, good pressure. Then master cylinder failed. So that will be next. Bearings and rear axles looked good. Cleaned and re packed everything. Shoes looked ok, they were out of adjustment so wear is uneven.
Y
Y Offline
Y
Y Offline
Here is another shot from winter after getting the hoist fully functional
hoist work in the spring
Nice truck! can you shoot a pic of the lifts for your dump bed? Particularly the area where the hoist attach to the bed?
Thanks, Motoswiz
1948 Chevrolet 1.5-Ton Dually
More pix on Photobucket
Motoswiz
North Florida
