4 members (Otto Skorzeny, Joe H, HandyAndy, Phak1), 140 guests, and 1 robot.
Topics128,049
Posts1,055,546
Members48,425
#778916 09/07/2011 9:00 PM
Are there any specific lube points on the 3-sp column shift mechanism? My '53 is the first truck I've had with it and it seems a bit stiff or clunky to shift.
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
The factory manual only list lubricating the shift box on the column. If the current lube has been in there a long time, I would clean it out and add new lube.
Drew
Thanks Drew!
Allan
1951 GMC 1/2-ton
I'm on my way home from Kansas City and my shifter got stiff today. I narrowed it down to the top bracket. Some WD40 loosened it up. I don't remember if I lubed it when I installed it but it's coming apart for some white grease when I get back home.
I finally got around to taking my shifter apart. It didn't want to come apart. The top bracket is aluminum and the piece it threads to is steel. Apparently I didn't lube it when it went back together, not realizing that the shifter rotates on these threads in use. The threads in the top bracket are now ruined. I put it back together with a generous dose of Never-seeze. I hope it holds up until I can find a used bracket. They are not reproduced for the '54-up.
If you are putting one together I'd recommend a coat of anti seize on these threads.
i cleaned up the shifter box on my 56 3-spd, including the removal of all of the grease inside it (more like grease+dirt sludge). So... what should i replace this grease with? Cornhead seems too thin.
I'd be cautious about using chassis or wheel bearing grease esp in cold weather. Things may get a bit stiff. I think corn head grease would be just fine.
thanks Don
