| | | Forums66 Topics128,163 Posts1,056,921 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77909 05/23/2007 12:03 AM | Joined: Dec 2006 Posts: 3 Junior Member | | Junior Member Joined: Dec 2006 Posts: 3 | Does anyone know if I can switch out a 3 speed tranny in my 41 half ton for a 4 speed without any complications? Thanks | | |
#77910 05/23/2007 12:23 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | The answer is yes, but why would you want to? You can get a 4 speed crash box, that would give you a granny low and no syncronized gears. The 3 speed is much more driveable.
If you are considering a more modern 4 speed, it will take a little more work. The bolt patern in the front that mounts to the bellhousing is different, and there is also the problem with the torque tube rear end. For the hassel involved, you would probably be happier with the 3 speed, or converting it with a T-5 5 speed. That is just my $.02. | | |
#77911 05/23/2007 4:02 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | There are a couple of other thing you will need to do for the swap you are talking about. One is that you will need to do some adjustments to the pedal assembly. The 4 spd is wider than the 3spd so the extra material on the pedal assembly where it bolts to the trans will heve to be removed. Also you might have to change the u-joint. As bigbad... said the 3spd is a much more driveable trans. | | |
#77912 05/24/2007 3:15 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Unless, of course you want to pull stumps. My manual lists the 4 speed first gear as 7.226 to 1. I have this in my ¾ ton and it is pretty much useless for normal driving. Now that “unsynchronized stuff is a whole nother story. It is great, as not many people will ask to drive it a second time  | | |
#77913 05/24/2007 1:40 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | If you are like me - I just wanted a 4 speed floor shifter instead of the 3 on the tree. So, I got one from Tom's Truck Parts in Tulsa.
They are a lot heavier. I think around 135 pounds. But you can do it. Get what you want. Just put an add in the Truck Parts Wanted section.
My take on this.
Dennis -there is nothing stronger than the heart of a volunteer-
#77914 05/24/2007 2:30 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I buried my old 4 speed behind the garage,anyone is welcome to dig it up. | | |
