0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#778822 09/07/2011 3:09 PM
Hey guys over the last year I have given this truck a complete tune-up and with your help rebuilt the brakes. Never really drove the truck til Saturday. I was giving her a test run when I stopped and noticed oil had blown out of the fill pipe. I cant find a pcv valve and was told that year did not have one. Any ideas where to start. I do see a tube that looks like it is running from the rear of the carb down the back of the engine.
This is strickly a guess but that tube may be a vacuum line going to the brake booster or vacuum reservoir. Unfortunately I am of no help on the PCV valve but I'm sure many others can be.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Riding in the Passing Lane
Some of those had the pcv valve screwed into the back of the carb. Then had a hose that went to a cap on the outlet in back of the dis.
1972 Chevy c10 Cheyenne Super
Found the pcv valve behind carb last night. Still rattles when I shake it. Does this mean it is still good? Oil fill vent cap is very very gumed up.
Hd Offline
This is a physics problem:
The crank vent/fill pipe has positive pressure, the pcv line has negative pressure ... when one exceeds the other ... something's gotta blow.
Excess crank pressure from a "mature" engine is usually a ring/cylinder issue. Most likely the oil control ring(s).
The fix: hone / ring job
The cheap fix: Drain a quart, add a quart of Rislone get it hot and cross your fingers.
Otherwise: Hire it out for mosquito abatement.
-Hd
