7 members (1955 1 Series, Wayne67vert, Brian Moore, Jon G, KEVINSKI, 50Chevy3100, 1 invisible),
50
10
Mod | | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77899 05/22/2007 6:57 PM | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | okay so i got a 283 in my 63 c10 and it ran great until a few weeks ago when i was at work. ive had it for about a year and i can tell the engine is tired and im probably going to replace it this summer. anyway, i was letting a friend of mine mess with the engine outback while i was with him, just messing with the distributor a little bit and adjusting the fuel/air mixture and such. it sounded great. it sounded like it was running much smoother and everything seemed much better than before, with just that little bit of tweaking. so he leaves and then i drive it away a few hours later when i got off. now, again, in park the engine was running fine, i could rev it up and it was totally smooth. i get probably 100 feet down the road, get it up probably around 2000 or above rpms (just judging by the sound compared to my suburban, i dont have a tach in the truck) and the engine starts sounding really weird. it had almost no power, there was all kinds of missing going on, and so i was going down the road at about 15 mph trying to get it to get in its groove again but it just wouldnt. so eventually i just floored it and it finally kicked back into whatever the nice mode it was in earlier haha. so i get it home, it sits for a few days, and then i was going to drive it up to my dads becuase we were putting the new bed on up at his house. now once again, it sounded fine in park before i took it up to his place, and did fine driving down a pretty flat, straight road. so then i get to his street (his house is about a half mile from my place) and turn onto it and you have to go up a pretty steep incline for a few hundred feet. it pulls up the hill about a quarter of the way, and then same thing that happened a few days earlier happened-lost all power and torque, just wasnt pulling at all. it sounded really weird, all kinds of misses. the engine definitely didnt sound like a normal v8. basically what should have taken 30 seconds to get up took like 2 minutes of the truck just crawling up the street, barely able to move. so finally i get it to his house and park it and we leave it sit a few days before we're able to work on it. so we go there a couple days ago and decide to try to mess with the timing a bit. we get the timing light out, and the white timing mark on the (pardon me for not knowing the name of this part) was way off of what we thought it should be. so we rotate the distributor a bit to try to get it close to where it should be and it sounds like its running a lot smoother. so once again i take it out to test it, drive down the street and back up. now we had it in park and it sounds great. it revs up fine, no conking out, no crazy noises liek when its in drive. so i put it in drive, take it down the street, turn around and try to come back up. i probably got maybe 20 feet, and then it just starts doing all that crazy stuff again. it got so bad it would just end up dying and id have to start it back up and keep trying. i probably had to start it back up 7 or 8 times before i got all the way up the hill. i just dont understand why its fine in park, and then gets all whacked out and weird in drive. we were thinking about replacing the sparkplugs, wires, and distrubutor to start, so we can just start with something fresh. just wondering if anyone has any idea of whats going on. basically the main idea im trying to get across is that in park, when its not having to push anything, the motor does great, and then when you put it in drive, when its actually needing to move something, it just ends up dying, and it never did this before my friend messed with the carb and distributor. thanks for any help. | | |
#77900 05/22/2007 7:09 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Sounds like crud in the gas tank to me. | | |
#77901 05/22/2007 7:16 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 63custom,
When the engine was timed did someone remove the vacuum advance line and block the carburetor port. After timing, the line should have been put back on. I wouldn't go nuts right now with wires, plugs etc. This problem will be solved and all will be good again...don't throw more unknowns into the pot just yet! Great explanation of the problem..A+.
Stuart | | |
#77902 05/22/2007 7:27 PM | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | no we didnt mess with the vacuum advance at all. we were just using the timing light and adjusting the distributor. we just cant understand why it does fine in park, but not in drive. i saw another topic called "Carb or distributor" or something like that where a guy had a similiar problem and they recommended something with the vacuum advance so i'll have to look into that. | | |
#77903 05/22/2007 7:32 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 63custom,
The timing should have been done with the vacuum advance disabled. Pull the vacuum hose and plug the carburetor end of it and try your timing again. This would be a start.
Stuart | | |
#77904 05/22/2007 7:37 PM | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | alright, ill probably do that tomorrow. thanks. | | |
#77905 05/22/2007 8:05 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Check the point gap. Sounds like it,s too close. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#77906 05/22/2007 10:04 PM | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Under load or moving the truck requires more fuel, therefore I would check the fuel line, fuel pump and inline fuel filter to ensure there is no clogging or interuption of good fuel flow into the carburetor.
I had one that acted like that before and the fuel pump was on the fritz. A new fuel pump later and she ran like a champ. I have also had similar symptoms, only to discover the coil wire and a few of the plug wires were not properly seated at the distributor cap and spark plugs. When changing plugs or wires, I put dielectic grease on the connector boots at the plugs and the cap, to ensure a good connection.
I hope you are able to solve your dilemma.
Tony | | |
#77907 05/23/2007 4:19 PM | Joined: Feb 2007 Posts: 18 New Guy | | New Guy Joined: Feb 2007 Posts: 18 | Check the timing when it is running bad, may jump time due to sloppy chain or worn distributor. But is sounds like water or crud in the fuel. | | |
#77908 05/24/2007 1:49 AM | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | it ended up being the choke was stuck. we messed with the timing a bit, tweaked the carb, and shes burnin rubber just fine!! | | |
