9 members (48jim1ton, Gdads51, Forty9, Hotrod Lincoln, gswbbc, frogfarmer, Wayne67vert, sron48, dt235sd),
75
0
Mod | | | Forums66 Topics128,043 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Are there any specific lube points on the 3-sp column shift mechanism? My '53 is the first truck I've had with it and it seems a bit stiff or clunky to shift.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The factory manual only list lubricating the shift box on the column. If the current lube has been in there a long time, I would clean it out and add new lube.
Drew
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'm on my way home from Kansas City and my shifter got stiff today. I narrowed it down to the top bracket. Some WD40 loosened it up. I don't remember if I lubed it when I installed it but it's coming apart for some white grease when I get back home. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I finally got around to taking my shifter apart. It didn't want to come apart. The top bracket is aluminum and the piece it threads to is steel. Apparently I didn't lube it when it went back together, not realizing that the shifter rotates on these threads in use. The threads in the top bracket are now ruined. I put it back together with a generous dose of Never-seeze. I hope it holds up until I can find a used bracket. They are not reproduced for the '54-up.
If you are putting one together I'd recommend a coat of anti seize on these threads. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i cleaned up the shifter box on my 56 3-spd, including the removal of all of the grease inside it (more like grease+dirt sludge). So... what should i replace this grease with? Cornhead seems too thin. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I'd be cautious about using chassis or wheel bearing grease esp in cold weather. Things may get a bit stiff. I think corn head grease would be just fine. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | | | |
