7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible),
125
Mod | | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Anybody have a bad experience mixing Kirker's 2K high build urethane primer with a PPG urethane topcoat?
Of course PPG will recommend buying their double priced high build primer, but any seasoned wise ones out there know better?
Dave
| | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | Yes, I have outstanding performance from the two. I painted the running boards over two years ago on my 1950 Chevy using Kirker UP732 2K urethane primer surfacer followed by PPG Concept DCC9000 acrylic urethane in gloss black. The finish is extremely durable no chips or scratches even with the constant stepping in and out of the truck. I plan on using the same combination on the 1952 GMC I am currently restoring. | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Thanks, Huck, mine's a 52 GMC as well by the way.
I was thinking of doing PPG's urethane enamel for the price. Any thoughts on that?
Also, forgot to ask how many gallons of high build are typically needed for these trucks?
Dave
