1 members (UtahYork), 108 guests, and 2 robots.
Topics128,049
Posts1,055,679
I ordered the 2v Holley from Langdon's along with the headers. I followed instructions and had the carb mounted tonight and started the truck for the first time, everything went great. When mounting the air cleaner I noticed the carb adaptor and intake bathed in gasoline. I then traced the leak to a 5/16 port in the base on the front of the carb, the fuel inlet side. It wasn't plugged with a brass plug, unlike two other ports on the carb.
My question is , should it be? This is something I could fix without the hassle of sending it back to Langdons.
1962 C-10 Chevy
More pix on Photobucket
ADHD and luvin' it
It's the rod the butterfly hinges on. Would the floats be the problem?
All replies appreciated.
1962 C-10 Chevy
ADHD and luvin' it
You might want to post the model number (and year). Langdon sells a 2-barrel Holley-Weber I think). There were also 2 barrel Holleys used on early V-8s (I think)?
Thanks for the suggestion, not thinking on my part.
It's a Holley 5200. Looks like throttle shaft leaking. Doesn't leak when running, only after engine turned off.
If it's a matter of adjustment, I could use a little tutoring in how to do it.
thanks
1962 C-10 Chevy
ADHD and luvin' it
OK, it is not dirt between the needle and seat, floats are good. The fuel bowl will drain dry in a short time.
Eureka, I found a tech sheet on this carb. What does the power valve do?
1962 C-10 Chevy
ADHD and luvin' it
