6 members (Hotrod Lincoln, 48ed56pam, Ponchogl, lumbersawyer, MickeyP, Bill Hanlon), 136 guests, and 2 robots.
Topics128,081
Posts1,056,073
Members48,434
#777821 09/03/2011 8:24 PM
Anyone know what the color is on the needles on the gauges and speedometer. Mine are faded pretty badly and need to be redone. Any information on reworking the instrument panel would be appreciated. It is a 65 Chevy...thanks...RC
RAC65 #777895 09/04/2011 1:19 AM
Check this out:
Gauge face decals
Not sure if it was the correct thing to do, however I went to the hobby shop and found a good florescent color that closely matched and used that when I painted my needles. Unless I am looking at the wrong bottle, what I used was called florescent hot pink.
Then just protected my gauge face and painted the needle with a small brush.
By the way, even if you use only water, if you scrub your gauges too hard you will go through the paint. So be careful.
Rusty64 #777933 09/04/2011 3:48 AM
Thanks for the info guys. The numbers on the glass for the speedometer are also damaged,maybe I can find something to fix them also. Thanks again....RC
RAC65 #777990 09/04/2011 2:25 PM
Nail polish works good on the needles too.
Also used colored plastic file folder material for restoring the turn signal and generator and hot n cold lights
The glass is twice as big as it needs to be.
Riding in the Passing Lane
I put paper under the needles & spray them with Chev. orange engine paint.
1972 Chevy c10 Cheyenne Super
Good call Wrenchbender. Hobby Lobby and the auto parts stores sell speedo needle orange. I poke a hole in the center of a piece of clear plastic wrap and insert the needle though it, to protect the gauge face.
Thanks for all the help .....RC
