0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#777292 09/02/2011 3:43 AM
Hello fellow chevy fanatics! Can anyone tell me an average cost to have my 66 short box fleet side rewired? It has a sb 327, Muncie 4 speed. It also has a key off battery drain, that can't be found, any advice/suggestions will be greatly appreciated!!
autowire
"you can't fix stupid"
E-Z wire for 189.00 you do the labor.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
k10 Offline
About 35 bucks for a good kill switch like this
k10 #777604 09/03/2011 4:15 AM
these guys specialize in factory-correct wiring harnesses for many years, makes and models, including '60-'66 Chevy trucks.
Factory-correct/factory-fit wiring harnesses for your '66 Chevy truck
As you have noticed, there are many suppliers of wireing kits.
I did mine with a lot of help from my friends and would hire it done next time. The under dash was a s.o.b.
I purchased the american autowire kit, I tried the install myself. The kit needed to be cut to size and the connectors installed. The way i saw it without the correct crimping tool great connections that I could trust couldn"t be made. I priced this tool @ 100 bucks. I had it professionally installed, the guy routed it, installed the conduit, and tucked it away very neatly. He charged me 500 for the complete install and it looks like one of the hot rod shows did it.
I used the Ron Francis wiring harness in my 65 was very easy took about a week in my spare time to wire the whole truck. about 20 hrs to do the job.If you have trouble they are there to help
In 4-6 you can install the following from M&H and the price is comparable to the other aftermarket harnesses on the market:
M&H Electric Fabricators, Inc.
13537 Alondra Blvd.
Santa Fe Springs, CA 90670
Sales & Customer Service: 562-926-9552
Technical Support: 562-926-9562
Fax: 562-926-9572
E-mail: [email protected]
Item #: Description: Price:
30775 Heater Blower – Switch-to-Block $ 7.00
19935 Cigarette Lighter $ 7.00
19940 Heater Bezel Lamp – Deluxe Air $ 11.00
19945 Taillight–Firewall-to-Rear Cross Sill $ 35.00
19930 Backup Lights – Rear $ 20.00
30620 Dome Light $ 16.00
30845 Taillights–Rear Cross Sill-to-Buckets $ 45.00
19960 Fuel Tank Sending Unit-to-Block $ 13.00
22570 Main Under-dash Harness & Block $259.00
04685 Dash Cluster-Gauges $ 58.00
02667 Park Lamps $ 32.00
39578 Radio-to-Block $ 14.00
21125 Battery – Positive $ 39.00
30175 Wiper Motor-2 speed $ 21.00
04870 Battery – Negative $ 39.00
18000 Glove Box Courtesy Light $ 16.00
30645 Backup Lights – Intermediate $ 17.00
04715 Primary Under-hood–Voltage Regulator $ 93.00
30830 Engine – V8 $ 51.00
19925 Heater $ 20.00
19965 Factory A/C & Heater $ 98.00
20840 Factory A/C Extension Harness $ 9.00
20670 Factory Tachometer – V8 $ 22.00
These are the harnesses used on a ’66 Chevy K10 (1/2 ton, 4x4) long wheel base, fleet-side with a factory 283 V8 with factory points distributor, 4-speed floor shift transmission with factory air conditioning, 2-speed wipers, Deluxe-Air heater/defroster & tachometer.
