2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#77820 05/21/2007 5:23 AM
Apprentice
Apprentice
I am in the middle of putting the emergancy brake system back on my 1953 3100 chev truck when I discovered that the rear end I am working with is a newer rear end with different rear brakes.
The numbers on the rear end are GM 21, N1249518,
and 6116 or G116. The rear brakes have self adjusters and the backing plates have no holes for manual adjustments.
Any help would be appreciated.
Brian
#77821 05/21/2007 5:37 AM
kanskybrian,
You should be happy...a newer rear end with possibly a much better gear ratio. I can't decipher your numbers, but I think there should be a adjuster slot somewhere as even self adjusting brakes usually require a manual adjustment to get them in the ballpark. Did you look for a small spring clip with ears that covers the adjusting hole.
Stuart
#77822 05/21/2007 5:47 AM
Apprentice
Apprentice
I will look thanks
Brian
#77823 05/21/2007 8:46 PM
Riding in the Passing Lane
You evedently have an open drive shaft then. Someone has saved you a lot of work. Automarc is right. There is a slot somewhere. Sometimes there is a knockout in the backing plate & sometimes its on the drum.
1972 Chevy c10 Cheyenne Super
