0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 66 | I have a 35 1 1/2 ton with a 4 speed in it. does anyone know what type trans it is name/ number I would like to get a rebuild kit or parts and some info on it, is there a company that sells parts. it's a non synchro right. A bearing company near me wanted $100 for one bearing, so I'm asking some real bolters thank you | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | If you have the 4 speed with the lock out reverse, I will give you an entire trans. It worked well when I crated it up a few years ago.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
