| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | I ordered the 2v Holley from Langdon's along with the headers. I followed instructions and had the carb mounted tonight and started the truck for the first time, everything went great. When mounting the air cleaner I noticed the carb adaptor and intake bathed in gasoline. I then traced the leak to a 5/16 port in the base on the front of the carb, the fuel inlet side. It wasn't plugged with a brass plug, unlike two other ports on the carb.
My question is , should it be? This is something I could fix without the hassle of sending it back to Langdons.
| | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | It's the rod the butterfly hinges on. Would the floats be the problem?
All replies appreciated. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might want to post the model number (and year). Langdon sells a 2-barrel Holley-Weber I think). There were also 2 barrel Holleys used on early V-8s (I think)?
| | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | Thanks for the suggestion, not thinking on my part.
It's a Holley 5200. Looks like throttle shaft leaking. Doesn't leak when running, only after engine turned off.
If it's a matter of adjustment, I could use a little tutoring in how to do it.
thanks
| | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | OK, it is not dirt between the needle and seat, floats are good. The fuel bowl will drain dry in a short time.
Eureka, I found a tech sheet on this carb. What does the power valve do?
