1 members (Ponchogl),
182
0
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Bigtonka, judging by the pictures I don't think the installed relationship between the axle and the U bolt plate will change by which end faces the front of the truck. The important thing is to get the axle lined up with the spring center bolt, and tighten down on the U bolts uniformly, so that they all carry the same load and hold the axle in place firmly, hope that helps. | | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | Do you have shocks? I believe that the thicker side was where the shock brackets bolted. No shock, probably does not matter. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | 3B - I thought the same, but figured I'd check with "da boyz"...
Line up with the spring center bolt - check.
Donf - no, no rear shocks, guess I'll point them both in the same direction just the same. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I'm glad to see I'm not the only one who has to kneel in rocks to work on a truck! :mad:
Bruce | | | | | Joined: Nov 2010 Posts: 109 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 109 | Probably has to do with balancing the torque of the drive shaft. Most of the time you are in a forward direction, so it probably helps eliminate wheel hop. Most people who have tried to take off too fast in reverse have noticed it is fairly easy to get wheel hop.
If you ever raced a leaf spring rear car like a Nova you know what I mean.
2 cents | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | I'm glad to see I'm not the only one who has to kneel in rocks to work on a truck! :mad:
Bruce Oh man - I'm so SICK of the rocks!! I had brought the truck to my inlaws land to do the blasting and paint, I just got it back in my concrete garage tonight! I missed the concrete! | | |
