Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (68ironhead, Ridgeback, 78buckshot, Oswald), 101 guests, and 6 robots.
Topics128,274
Posts1,058,436
Members48,490
#777853 09/03/2011 10:18 PM
This winter I plan to remove the bed of my 49. Apart from the 6 long bolts what else is there? I am thinking of taking off the fenders with the bed as long as I can get enough strong bodies to lift. Otherwise I'll leave them on the truck. The wood boards will come out first.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Sedgewick #777863 09/03/2011 11:02 PM
I just did that to my 49 3100 you will also need to remove the running board bolts to rear the fenders and support bars under rear fenders to frame. Then 2 people can lift it off
josh
sinistar #778103 09/05/2011 12:58 AM
If you plan on lifting it off in one piece,leave the floor in.The box will be awful floppy otherwise.The tail light wiring will need to be disconnected
BC52 #778195 09/05/2011 8:26 AM
Taking the wood out does remove a fair bit of weight though.
I and two others easily lifted the bed off and kept everything 'square'.
Since then I have had the bed on and off a few times and didn't experience any problems at all.
Just be careful......
More pix on Flickr.
Thanks for the help.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
