4 members (Barry Martak, Gib70, Gray_Ghost, 55shaker), 64 guests, and 3 robots.
Topics128,129
Posts1,056,695
Members48,452
Big Bolt Forum Co-moderator
Well, tomorrow I think I'll be getting into the driver's side corner of my 1948 2 ton. I will shopping for parts and supplies. I'll be needing a spot weld cutter and carbide de-burring tool, looks like the inner and outer cowl pieces, and most likely the piece between the inner and outer, but it looks pretty good. But I'll see once I start cutting into the metal. I'll be back asking questions once I get going. I saw some good links for putting in patch panels, but will continue to study. I don't have a TIG, but I do have a MIG. Jump in with any good tips or more links if you like.
1948 Chevy 2-Ton
If you haven't already seen this,you could do worse than 'check' this link (pun intended!)
'Woody' Czechman's cabrot page.
Good luck!
More pix on Flickr.
Good luck!
Thanks. I did find that one earlier today and bookmarked it. It's very clear on the steps. I'll try and document my work too. It is my first attempt, so I am sure it will be slow and steady. I may have to attempt some pieces for the outer fenders from scratch since they are two ton fenders.
1948 Chevy 2-Ton
Good luck Super55
i have a conection in Kalowna that i am sure will be of help to you. I will make contact and get back to you.
layback
Is it a fellow with restored AD that works in the concrete business? If it is, I have seen his truck. He did a great job on that one, he also has an Art Deco model last time I was in Kelowna. That's about 4-5 hours from me.
1948 Chevy 2-Ton
Couple things I can offer is first to get your sheet metal welding process down with your mig. I found the best way for me was to use compressed air to cool the piece down right after you do an inch or so bead. Be careful though, I got a 3/16 size hole in my knee from setting the gun down to fast... grin
Other thing is get ready for some fun in trying to make those inner cowl pieces fit. I had to cut the bottom off mine, re-shape them to fit and then weld them back on.
Dave
