| | | Forums66 Topics128,128 Posts1,056,666 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Well, tomorrow I think I'll be getting into the driver's side corner of my 1948 2 ton. I will shopping for parts and supplies. I'll be needing a spot weld cutter and carbide de-burring tool, looks like the inner and outer cowl pieces, and most likely the piece between the inner and outer, but it looks pretty good. But I'll see once I start cutting into the metal. I'll be back asking questions once I get going. I saw some good links for putting in patch panels, but will continue to study. I don't have a TIG, but I do have a MIG. Jump in with any good tips or more links if you like. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | If you haven't already seen this,you could do worse than 'check' this link (pun intended!) 'Woody' Czechman's cabrot page. Good luck! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Thanks. I did find that one earlier today and bookmarked it. It's very clear on the steps. I'll try and document my work too. It is my first attempt, so I am sure it will be slow and steady. I may have to attempt some pieces for the outer fenders from scratch since they are two ton fenders. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | Good luck Super55 i have a conection in Kalowna that i am sure will be of help to you. I will make contact and get back to you.
layback
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Is it a fellow with restored AD that works in the concrete business? If it is, I have seen his truck. He did a great job on that one, he also has an Art Deco model last time I was in Kelowna. That's about 4-5 hours from me.
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Couple things I can offer is first to get your sheet metal welding process down with your mig. I found the best way for me was to use compressed air to cool the piece down right after you do an inch or so bead. Be careful though, I got a 3/16 size hole in my knee from setting the gun down to fast... Other thing is get ready for some fun in trying to make those inner cowl pieces fit. I had to cut the bottom off mine, re-shape them to fit and then weld them back on.
Dave
