8 members (Otto Skorzeny, DavidBraley, Paul Mullen, Gray_Ghost, Gdads51, Hotrod Lincoln, Ponchogl, 1 invisible),
97
Mod | | | Forums66 Topics128,185 Posts1,057,200 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 70 | I'm looking into doing an AD build for a truck used for my construction business that will be equal parts for work and for show.I expect to basically use an AD cab and body and mount it to a more modern frame and drive train.
I expect to strip the cab down bare and get to work on it.I will have it media blasted and then figure out what I have.
Well,what can I expect?What will I most likely have to replace and patch in?What patch panels are available? Is there any reason to be optimistic about the condition of things?
I haven't bought anything yet.I haven't yet begun actively looking.I just want to get an idea of the things that I will definitely be replacing,body wise,no matter how much searching I do.
From the cab on back,I will fabricate the bed.I'm not really interested in frame or running gear.Just want to know what I will be getting in to.I'm in the Northeast,so the chances of finding something decent locally,body-wise,is probably less than most other places.
Thank you for any advice I can get. | | | | | Joined: Jun 2011 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 117 | Popular places for AD cab rust: front floor, kick panels, outer lower cowel, rocker panels, rear bottom cab corners.
Look through the sheet metal section in the Jim Carter catalog, if they sell it then it's a place that might be rusted on an AD cab. | | | | | Joined: Nov 2004 Posts: 2,422 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,422 | If you are thinking about a big bolt, there are lots of farm trucks still out there with minimal rust. As far as parts go, I believe you can buy new patch panels for all of the usual problem areas.
Good luck
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | USA is a big place with many different climates and rust issues. Where you are will have a pretty big impact on what you find. If you have the access to or money for shipping I would look in the arid southwest for good metal to start with. | | | | | Joined: Aug 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 70 | USA is a big place with many different climates and rust issues. Where you are will have a pretty big impact on what you find. If you have the access to or money for shipping I would look in the arid southwest for good metal to start with. Yes,can't argue with that.But,I can't see buying anything sight unseen,and I don't see myself traveling across the country to find a decent body. I haven't started any hardcore searching yet,but it seems there are a lot of the AD trucks around here,that people have bought as projects.I found a lot of ads of folks selling AD trucks,in various stages and condition,without even trying. I'm thinking it might be likely to find someone in the middle of a project who may be selling a pile of stuff due to loss of interest or something.Provided they haven't made a bigger mess of things along the way. Picking up someone elses lost project on the cheap,is that in bad taste or bad karma? I know,it isn't as sexy as falling in love in a farm field,but in these parts it may be more likely.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | USA is a big place with many different climates and rust issues. Where you are will have a pretty big impact on what you find. If you have the access to or money for shipping I would look in the arid southwest for good metal to start with. Yes,can't argue with that.But,I can't see buying anything sight unseen,and I don't see myself traveling across the country to find a decent body. I haven't started any hardcore searching yet,but it seems there are a lot of the AD trucks around here,that people have bought as projects.I found a lot of ads of folks selling AD trucks,in various stages and condition,without even trying. I'm thinking it might be likely to find someone in the middle of a project who may be selling a pile of stuff due to loss of interest or something.Provided they haven't made a bigger mess of things along the way. Picking up someone elses lost project on the cheap,is that in bad taste or bad karma? I know,it isn't as sexy as falling in love in a farm field,but in these parts it may be more likely. By the time you finish the 10th patch panel and notice the rust rot around the windshield that was covered by ten pounds of Bondo and that your local purchase is not so juanderful, you may wish you had gone to the the west coast to pick up your Bolt.
~Jim
| | | | | Joined: Aug 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 70 | By the time you finish the 10th patch panel and notice the rust rot around the windshield that was covered by ten pounds of Bondo and that your local purchase is not so juanderful, you may wish you had gone to the the west coast to pick up your Bolt. I've never been to that part of the USA.Would an AD truck that spent it's life there be expected to be in excellent condition,body-wise? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It's all about odds/%. The dryer climates (west of the Pecos)tend to protect steel from that nasty cancer called rust. In areas east of the Mississippi, you can certainly find relatively rust free projects; it is just harder to do. Also if you confine your search to the eastern seaboard your odds are not as good. Rather than riding through the country (not a bad idea) looking for your next truck,I would check with all the internet sites for trucks for sale, request pictures of likely rust areas and pick the best $ value. Good luck!
~Jim
| | | | | Joined: Jul 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 89 | just me or are the inner door bottome prone to rot as well?
it ain't YOURS 'till it ain't stock!
1951 chevy 3100
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | There is a hole/holes in the bottom of the door and as long as they drain as designed the rust should be minimal. There is no area immune to rust. Like was said before, check all the vendors for patch panels. They will sell panels for all the major areas.
~Jim
| | | | | Joined: Aug 2011 Posts: 15 New Guy | | New Guy Joined: Aug 2011 Posts: 15 |
We lust for what we want, and weep for what we need.
~Jim
