6 members (Bwana-Jim, J Lucas, Hotrod Lincoln, Jon G, Otto Skorzeny, MikeE), 101 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#77726 05/18/2007 12:55 PM
1955 - first - motor , rebuilt & balanced , put in a 1939 car . upgraded to 12 volts . had the ring gear " flipped " on the flywheel . she REALLY spins over now , but once in awhile the starter does not engage , sorrta just grinds . after 3 or 4 times of this , it does finally engage . what is the problem & what is the cure ?
thanks for your help . ohwell project 39
Ex Hall Monitor
Ex Hall Monitor
Worn gear on the starter shaft????? An adjustment issue???? I converted my old 55-1st to 12 volts & never experienced that problem.
project 39,
Did you put a solenoid actuated starter in you car or stick with the foot-masher? I have seen folks mention that the ring gear was 'handed' but I don't know if this is true.
Stuart
a foot masher - i like that : )
the starter was rebuilt - new drive on it .
i'm wondering if the guy who flipped the ring gear did not put it on squarely ?
You can drop the inspection cover and check the ring gear by eye.It should be tight against the step in the flywheel.Other than that,a worn nose bushing will cause it not to engage.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Riding in the Passing Lane
Some times the drive on rebuilt starters are not any good. I like to use new drives. It,s a one way clutch & if it slips inside it sounds like teeth grinding or sometimes just whirls & doesn,t turn the engine. Your switch on top the starter may be starting the motor too soon & not engauging the flywheel.
1972 Chevy c10 Cheyenne Super
#77732 05/18/2007 10:23 PM
Been a long time since I worked on a foot stomper, but if my memory is any good at all the switch on the top of the starter had slotted holes. This allows you to move it slightly. Try moving it away from the linkage so that the drive gear is more fully engaged before the switch closes.
#77733 05/18/2007 11:08 PM
thanks guys for all the great ideas ! smile
