3 members (Otto Skorzeny, MNSmith, tclederman), 73 guests, and 1 robot.
Topics128,052
Posts1,055,718
Can I quicken the steering on my 55 series II pickup by lengthening the pitman arm 1"?
Does anybody know where I can get an altered pitman arm?
The security of your steering system is so important that I recommend being very careful when making changes. I would rather use a replacement pitman arm that is one piece (but a little bit longer) than modify your existing arm. Is there any way one of your friends has a pitman arm of the size and shape you plan that you could borrow to check how it works. I also do not understand the geometry of the steering system enough to be sure if your planned change might have other (bad) effects besides the good effects you want you plan.
Yes it will speed up the ratio, BUT it will also increase the effort you must apply to turn. Is it a good idea, Absolutely not, thats a cast piece that takes a tremendous amount of force and welding to it will surely weaken it.
Most GM's used the same splines on the pitman arms so shop around for something that might get you were you want.
Putting a much smaller steering wheel on will have the same effect, almost!
Joe
