3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#77703 05/18/2007 3:29 AM
Junior Member
Junior Member
1 Offline
I have a 1950 3/4 ton truck with a 4 speed in it. The engine was swapped to 235. I have a 1948 1 ton rear end in it. My problem is it is wrapping all kinds of RPMs at 45 miles an hour. I cant get it up to 55 without the motor sounding like it will over rev and fly apart. I have the transmission that matches the rear end out of the 48 sitting on the shelf. I am wondering if I swap the transmission to the one that originally went with the rear end, would it give me a better ratio? Or was this rear end just not made for today's speeds? Thanks
"It ain't the years that hurt, its the mileage"
#77704 05/18/2007 3:39 AM
They are both direct drive in high gear. Doug
#77705 05/18/2007 3:48 AM
Going back to the 3/4 ton rear would help some (4.56 ratio compared to 5.13). Either way, they're not really meant for high speeds. The best bet would be to find a '67-'72 3/4 ton 3rd member with the 4.10 ratio. It's a bolt in for the current 3rd member.
Bill Burmeister
#77706 05/18/2007 4:35 AM
Bill is right.
Your other option is an overdrive transmission like a T-5.
But really you are running stump pulling gears in the rear and that is where your problems starts.
#77707 05/18/2007 3:25 PM
Don't you have to modify the drive shaft or have it reworked fot that swap Bill? That is the 67-72 3/4 ton pumpkin swap! Also, can you use a 3.something ring and pinion in that newer carrier???
I wouldn't know where to start but I sure wish we could pull all of this 3/4 ton rear info together into a complete tech tip since it comes up so often.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#77708 05/18/2007 4:08 PM
I just went through this whole thing. Had to shorten the driveshaft a little, and 4.10 is the highest road speed option, but I am completely satisfied with the results.
Before: 5.14 final. 45mph = fastest sustainable cruise. Comfortable road speed was 35 - 40 mph.
After: 4.10 final. Relaxed and comfortable at 50 - 55 mph, fastest sustainable = somewhere over 60 mph.
BIIIIIG difference! This was a farm truck, now it's a road truck.
1951 3800
-hotshoe
#77709 05/18/2007 10:03 PM
you could just do what i do: drive slow and PO everyone behind you. it was the cheapest and easiest for me.
#77710 05/19/2007 2:02 AM
Quote
I've heard that there is a 3.9 or 3.7 gearset available, but its rare and hard to find. It wasn't used very many years and was little used in those years.
If I knew the details I'd share them. Some searching here is likely to turn up more information. What you are looking for is a late 60's early 70's C-20 with an automatic. Big block suburbans seem to me the most likely place to find them.
It might be less trouble to swap rear axles.
#77711 05/28/2007 7:23 PM
Junior Member
Junior Member
1 Offline
Thanks for the help fellows. I was making sure there was nothing I could bolt in that I already had on the shelf to make it better. I think I will drive it the way it is for now, but when I get a chance I will put a higher rear end in it.
