| | | Forums66 Topics128,050 Posts1,055,704 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Can I quicken the steering on my 55 series II pickup by lengthening the pitman arm 1"? Does anybody know where I can get an altered pitman arm? | | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | The security of your steering system is so important that I recommend being very careful when making changes. I would rather use a replacement pitman arm that is one piece (but a little bit longer) than modify your existing arm. Is there any way one of your friends has a pitman arm of the size and shape you plan that you could borrow to check how it works. I also do not understand the geometry of the steering system enough to be sure if your planned change might have other (bad) effects besides the good effects you want you plan. | | | | | Joined: Feb 2000 Posts: 5,201 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,201 | Yes it will speed up the ratio, BUT it will also increase the effort you must apply to turn. Is it a good idea, Absolutely not, thats a cast piece that takes a tremendous amount of force and welding to it will surely weaken it.
Most GM's used the same splines on the pitman arms so shop around for something that might get you were you want.
Putting a much smaller steering wheel on will have the same effect, almost!
Joe | | |
