1 members (mick53),
202
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | We are probably going to try and start 55 3100 with Hydramatic this week. It has been sitting for a little over 30 years. Any special considerations for the transmission? What kind of oil does it take? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Type A AT fluid was originally used.
People use Dexron Type II (or, Type III), not Type F.
Or, call Gene Berck at Restoration Hydramatics in Salinas, CA
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Type A was made from whales or something like that causing it's end of manufacture.
The advice that I got was the same as Tim mentioned with Dextron.
I was told that type F would be too tough on the soft frictional surfaces of the clutches and bands. | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | I called Gene a few months ago an he said to use Dextron lll ... Vavoline Label
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
