Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Dakota Bob, TUTS 59, Otto Skorzeny), 109 guests, and 2 robots.
Topics128,282
Posts1,058,492
Members48,490
I am looking at new wheels for my truck. The original wheels have a lot of corrosion inside and are pretty banged up. I measured the original wheels and they have a 3 1/2" backspacing. I went over wheels with my daughter since it we are doing this together and she chose Wheel Vintique series 13 chrome / bare steel rims. They are 16 x 7 with a 4" backspace. With the center painted black they will look similar to the original wheels. When I had the truck on the lift it appears that clearance should be OK but in seeing another post on 15" wheels someone commented that the backspacing would not work.
Does anyone know if these will work? Does anyone have these wheels and what do you think of them? Thanks
You will definetly want to go with the 3 1/2" backspace over the 4". In addition to tie rod clearance issues, the 4" backspace will also allow the left wheel to contact the drag link on a left hand turn. Found that out the hard way. Had a customer that wanted a 15x7 wheel, which at the time was only available in a 4" backspace Japanese truck fitment, instead of the 15x8 Chevrolet 4x4 fitment that had the 3 1/2" backspace. While they did just barely clear the stock tie rods, the wheel did contact the drag link. I went with the 3 1/2" backspace wheel on my virtually identical truck (his was a shortbed, mine is a longbed), I have no clearance problems with either the tie rods or the drag link.
Wheel Viniques should be able to make the wheel with the 3 1/2 backspacing. We just installed a set of wheels from them on a '30 Model A that were custom ordered with a 15x5 up front with 2 1/2" backspace, and 15x10 on the rear with 3 1/2" backspace. They were the only company that would make that combnation, everyone else only had a 4" backspace with a 10" wheel, which would not fir without spacers. They quality was top notch, with very solid welds from the disk to the rim. Runout was very minimal, the wheels themselves were less than 1/4 ounce from true balance.
Bill Burmeister
The 15 x 8 Chevy Blazer wheels that Longbox55 mentions work well on these trucks. Here's a picture of them on my truck.
Stuart.
Wow your truck looks nice. I will have to figure something out. My wheels are 16" and I just bought new tires. Thanks
I'M thinking of trying the 16" rims with the 4" Backspacing also on my 57 GMC.
How did yours turn out?
Make Love your strongest weapon. Compassion your shield and forgiveness your armor.
I think they look good. I have not had them rub. I mounted 225/75/16s on them. I will try to post some pictures this week.
