4 members (3800GUY, 3B, JW51, Lightholder's Dad), 125 guests, and 1 robot.
Topics128,130
Posts1,056,367
Members48,441
J Online: Content
Hello - I've developed an audible vacuum leak - sounds like it's inside the chamber. The unit is a circa 1970 Bendix diaphragm type that was rebuilt, but sat for a while after rebuild. I'm planning to open the can and look for sources of leaks....what should I look for, if any of you have serviced this type unit?
1955 GMC 630, 1959 GMC W660, 1958 Chevy Spartan 80
3B Online: Content
3 Online: Content
Hy jaycoop, make sure the clamp ring is tight and centered, other than that, you'll have to check the diaphragm for holes, hope that helps.
J Online: Content
Thanks, I'll take a look at those areas and hope it's a minor thing....
J Online: Content
Checked it out this evening - the perimeter grooves of the chamber were slightly rusted in areas, causing a tiny leak. I cleaned everything up and used a little dilectric grease on the diaphragm edge bead - and NO LEAKS. Thanks for the tips!
3B Online: Content
3 Online: Content
Hy jaycoop, great to hear/read.
