2 members (Gib70, Tronman), 117 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#775678 08/28/2011 2:41 AM
Would like to know if I can use late model tubeless rims ? yes current rims are lock ring type yes its a dually thanks !!
Dado #775941 08/29/2011 1:32 AM
For my '62 I had to use the original flat base rims on the inside rear. Used later model drop centers on the outside rear and on the front.
Slick Willy #775945 08/29/2011 1:55 AM
Thanks ! I think i may be looking for a mid 80s dually and just do a swap first member and rear axel only issue i see is the clutch works off a slave cyl master cyl is duel purpose .
