| | | Forums66 Topics128,087 Posts1,056,114 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Hello - I've developed an audible vacuum leak - sounds like it's inside the chamber. The unit is a circa 1970 Bendix diaphragm type that was rebuilt, but sat for a while after rebuild. I'm planning to open the can and look for sources of leaks....what should I look for, if any of you have serviced this type unit?
1955 GMC 630, 1959 GMC W660, 1958 Chevy Spartan 80
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jaycoop, make sure the clamp ring is tight and centered, other than that, you'll have to check the diaphragm for holes, hope that helps. | | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Thanks, I'll take a look at those areas and hope it's a minor thing....
| | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Checked it out this evening - the perimeter grooves of the chamber were slightly rusted in areas, causing a tiny leak. I cleaned everything up and used a little dilectric grease on the diaphragm edge bead - and NO LEAKS. Thanks for the tips!
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jaycoop, great to hear/read. | | |
