| | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Removed the pump and found all kinds of mud and sediment in the bowl. I checked the supply from tank, and it looks good - clean gas runs out. Put a new pump in and everything seems fine. Been having hard time starting, now I know why. Thank goodness for the filter screen in the pump! Do you clean out your fuel pump every so often? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you're getting trash in the bowl it's coming from the tank. Short of pulling and cleaning the tank I would at least put an in-line filter between the tank and pump. It's cheaper to replace the filter than the pump. To answer your question, I've never had to clean the sediment bowl on my pump.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You are asking for trouble. As you put modern gas in more crap is going to come through. Take the tank out and get it cleaned. Tiny can give you some pics of what happens with bad gas. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | and who says a picture isn't worth a thousand words...... | | |
