| | | Forums66 Topics128,018 Posts1,055,339 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77531 05/13/2007 12:35 AM | Joined: Jan 2007 Posts: 23 Apprentice | | Apprentice Joined: Jan 2007 Posts: 23 | I've SEARCHED all the forums with no answer so here goes; took a 3 speed manual trans. out-gonna go back with a turbo 350. Will the speedometer cable hook up to the T350? Thanks for your help. Ray
Ray K.
#77532 05/13/2007 3:10 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Is it long enough? Probably has a different end to fit the transmission? | | |
#77533 05/13/2007 3:23 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It will hook right up. You will have to check the accuracy. Match the odometer up with the milemarkers on the freeway. The 350 is easy to calibrate. Remove the gear where the cable hooks up. There are a wide selection of gears with different number of teeth available. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#77534 05/14/2007 9:19 PM | Joined: Jan 2007 Posts: 23 Apprentice | | Apprentice Joined: Jan 2007 Posts: 23 | thanks for the replies. ray
Ray K.
