4 members (KEVINSKI, Guitplayer, Samantha, lumbersawyer), 109 guests, and 1 robot.
Topics128,154
Posts1,056,855
Members48,456
#773011 08/19/2011 4:54 PM
my panel has an odd gas tank and I was wondering if it is the same tank as a 2nd series pick up ?
mine seems to have a diagonal seam in it . I found a 2nd series tank used in great shape but want o be sure it will work before I buy it .
thanks again
Aerodynamics are for people who can't build engines.
--Enzo Ferrari
I just realized that the tank that is in there may not be for a 55 truck/ panel at all . I really have no idea if it's correct or not . I guess the question still remains is a 55 truck tank the correct or at least useable tank for a 55 panel ?
--Enzo Ferrari
yes you have an original panel tank, odd shape attached to the passenger side frame rail, the pickup tank is inside the cab behind the seat, wouldn't work too well in a panel wink
mike, i dont think it would work at all. the best bet in my opinion is to clean out your old one and seal it to prevent further rusting with stuff you buy online from summit for example (if the condition is not too bad). it will even fix pinholes if that's all you have. if it's beyond repair you have 2 choices: either find a good used one from a burb/panel or put a fuel cell somehow which would be alot more work to put under the vehicle (i dont trust fuel cells inside, unless its inside a trunk which you dont have). that's my 2 cents. hope that helps. -jrsotojr
Thanks fir the info ... Do you happen to have s pic of what a panel/ burb tank looks like . Trying to ID if what I have there is a correct tank . It seems to sit kinda low .
Mike
--Enzo Ferrari
I can't imagine finding any other than a one-off custom made tank fitting in the correct location to connect to the filler door ... from your original note of the 'diagonal seam' you have the tank all 55-59 panels and burbs had, which if properly retained by the original straps nearly touching the wood floor, doesn't hang too far below the frame, unless your retainer straps are wrong .... if you plan on having the truck long, get yourself an assembly manual, fuel tanks are in section 8
Well then I'll try and use the one on there if it's actually the right one
... Also means I have a 55 truck tank in real good shape to sell
--Enzo Ferrari
Sir Searchalot
Sir Searchalot
Just take a pic Mike and we will tell you!!!!!!!
--Enzo Ferrari
yes that's the original tank, but the strap hardware is not [the eyebolt particularly], and it looks like the straps are too loose
Ok I'll drop the tank and clean it up ... I haven't been under there much yet , do the original tanks have a drain bolt on them by chance
--Enzo Ferrari
Thanks for the help guys!!
--Enzo Ferrari
Sir Searchalot
Sir Searchalot
Like Squeeze said, nice orig tank. I don't get why you wanted to swap it out? take it off, put a little soap and water in it and a piece of chain or socks full of rocks and suspend it on some ropes and shake it all day. Clean out good, fill with water and see if it leaks. Acetone and some other solvents will work if it's real gummy inside. Swimming pool acid helps (Hydrochloric). Don't use muratic. You can get tank cleaning kits from POR/Eastwood and others. They do work well. Keep the stock one if you can, but they are only about 16-17 Gal.
I thought it was the wrong one because it sat so funny - I went by all the other stuff the D.A.P.O. did to it and just assumed it was a random tank . Glad I asked lol
--Enzo Ferrari
Anyone know of a good place to get panel parts ... Like proper tank straps
--Enzo Ferrari
there are no panel specific parts available that don't also fit the pickup, so no tank straps, you would have to get dimensions and pics from some one to fab some up yourself
