0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#77509 05/12/2007 3:03 PM
Apprentice
Apprentice
Hello All, Last night I installed my just purchased Holley 5200 from Langdon's Stovebolt. I can't get it to idle properly or run worth a s**t.It has no power and an excessive amount of play on the lower throttle plate shaft.Have any of you had any troubles?
Thanks John ohwell
#77510 05/13/2007 12:18 AM
hello John; I would give Tom a call at Langdon's,
when I installed the Holley-Weber on my 216 he gave me some good advice,he realey knows what he is doing
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
#77511 05/13/2007 2:57 AM
I had all kinds of troubles getting my 2x Holley Webers to run on my Offy intake. It seemed like a vacuum issue but I couldn't find it. I finally traced the problem to the gasket between the carb and adaptor. The gasket just wasn't cut right and it was leaking in several places. I made a new gasket to fit and she runs like a top. As someone said, call Tom - he's the master on these carbs.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
#77512 05/13/2007 3:00 AM
Are you running a single carb? If so, you may want to talk to Tom. He told me that one carb wasn't enough for that my engine. He talked me out of going back to my stock intake. We are talking about the progressive 2bbl carb used on the Pinto; right?
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
#77513 05/13/2007 2:08 PM
2 Offline
John I am sure that Tom will take care of any issues you have with any of his products. He is a stand up guy that is willing to help anyone with problems that come up.
Tom
#77514 05/13/2007 5:40 PM
Having used both H/W and C/W carbs from Tom Langdons Stovebolt Engine Co. (586) 739-9601 I found that you have to be a little careful when you bolt the carb to the adaptor. If you try to force the fit you will possibly have leaks. I found that if you drop the four bolts with a small washer pointing DOWN in the elongated holes in the adaptor,then coming up from the bottom, slide on the 4 hole gasket and set this assembly on the inverted carb. You may have to wiggle it around to get everything to seat properly. The key is to get the entire assembly together so that it is a LOOSE fit before you spin on the nuts evenly.
The H/W is a rebuilt carb while the C/W's are new. If you're unhappy with the carb condition I'm sure Tom will bend over backwards to correct the situation. A worn throttle shaft is not something he would expect you to accept. However, I would go through the bolt-up sequence again and see if that doesn't correct the problem. All three of my carbs from him were awesome right out of the box. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#77515 05/13/2007 7:49 PM
Apprentice
Apprentice
Thanks Dave. I did put all the bolts in just as you said, I also checked the base for leaks with propane just in case I had a leak.I'm just going to wait until Monday and try and get a hold of Tom.Thanks John
#77516 05/13/2007 11:16 PM
John, when you get a hold of Tom you might ask about a "new" not rebuilt carb. A friend of mine mentioned that he got a new one for a paltry ten additional bucks.
Worn throttle shafts will leak enough air so that you'll never be able to get a stable idle air setting.....a problem I found with most rebuilt 50 year old original carbs. I hope this doesn't turn you off on the H/W or C/W carbs....I would put them at the top of the list for things you could do to improve engine and drivability on our old trucks at a reasonable cost.
Dave
#77517 05/14/2007 1:12 AM
Like others have said give Tom a call and send it back if it has loose throttle shafts, you've got 30 days to return. The Holley Weber 32/36's are rebuilt, so you don't know what jets they have, sometimes they are missing. If you're running a 235 you kneed a minimum of a 60 or a 65 idle jet, just to get it to idle within 1+1/2 to 2 turns out. Check it before you send back, its the one on the outside on the choke side. There's more but if the shafts are bad get another. When you get the next one, take it apart and write down all the jet numbers, they take weber jets and you can get online, cheapest is from Carbs Unlimited. Good luck. Oh and why you are at it throw away Toms little individual metal pieces that hold the throttle shafts and make a proper horse shoe shaped replacemet that won't flex.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#77518 05/14/2007 11:46 PM
Apprentice
Apprentice
I talked to Tom today and he is shipping out a replacement N/C. Excellent people to deal with!!John
