0 members (), 79 guests, and 0 robots.
Topics128,035
Posts1,055,560
#774917 08/25/2011 3:15 PM
Can I put Radial tires on my stock wheels for my 1955 Second Series 3600 with split rims? Thanks,Scott
mrcaddy #774925 08/25/2011 4:07 PM
thumbs_up
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
Bruce K. #774975 08/25/2011 7:20 PM
Yes, but you'll need to make sure you get the proper type of radial tire (tube type), and use the correct tube and flap for them.
Bill Burmeister
LONGBOX55 #775040 08/25/2011 11:21 PM
??? Ran radials on stock rims for years and always ran them tubeless with no problem other than one rim that had a slow leak I ran with a tube.
Bruce
Bruce K. #775044 08/25/2011 11:58 PM
2 peice rims require tubes, as there is no seal between the peies of the rims. Also, running tubes in tubless tires can cause premature tube/tire failure due to exessive heat buldup from friction between the tube and tire due to the composition of the construction. Ths is especially true if the tire is heavily loaded or is run at highway speeds.
Bill Burmeister
LONGBOX55 #779840 09/11/2011 4:39 PM
OK Bill. I missed the split rim issue in the post. Mine were one piece 15" rims on the 3100.
Bruce
