| | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | I'm using a 69/70 GM column, so I don't know if this should go here or the Hi Po section. Anyway, like I said I've got a 69/70 GM column with an aftermarket custom type steering wheel. It's kind of small and very 80's looking, so I'd like to replace it with something with a little more class. It's got 6 mounting bolts in a circle, surrounding the horn button. It does have a working horn.
So is this the stock column/wheel mounting configuration for this type of column? Most custom wheels I see advertised have either three or five holes, but I never see six.
So do I need some sort of adapter, or do I need to just look for a steering wheel that has six mounting holes? I guess I need to know what I have before I can start looking for something to replace it with. Thanks!
1940 Chevy 1/2 ton, 12 volt, 350/350th
| | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | Every aftermarket steering wheel I've ever seen needs an adapter to fit any application. That way they make more money by selling you an adapter AND they spend less by not making a thousand different variations of each model wheel to fit specific applications.
| | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | Every aftermarket steering wheel I've ever seen needs an adapter to fit any application. That way they make more money by selling you an adapter AND they spend less by not making a thousand different variations of each model wheel to fit specific applications. Ah, so I guess I just need to remove my steering wheel and see what kind of adapter I have. Thanks!
