| | | Forums66 Topics128,039 Posts1,055,591 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | Can I put Radial tires on my stock wheels for my 1955 Second Series 3600 with split rims? Thanks,Scott | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 |
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, but you'll need to make sure you get the proper type of radial tire (tube type), and use the correct tube and flap for them.
Bill Burmeister | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Yes, but you'll need to make sure you get the proper type of radial tire (tube type), and use the correct tube and flap for them. ??? Ran radials on stock rims for years and always ran them tubeless with no problem other than one rim that had a slow leak I ran with a tube.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 2 peice rims require tubes, as there is no seal between the peies of the rims. Also, running tubes in tubless tires can cause premature tube/tire failure due to exessive heat buldup from friction between the tube and tire due to the composition of the construction. Ths is especially true if the tire is heavily loaded or is run at highway speeds.
Bill Burmeister | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | 2 peice rims require tubes, as there is no seal between the peies of the rims. Also, running tubes in tubless tires can cause premature tube/tire failure due to exessive heat buldup from friction between the tube and tire due to the composition of the construction. Ths is especially true if the tire is heavily loaded or is run at highway speeds. OK Bill. I missed the split rim issue in the post. Mine were one piece 15" rims on the 3100.
