2 members (dbwr, 1 invisible),
181
0
Mod | | | Forums66 Topics128,190 Posts1,057,342 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77483 05/12/2007 12:08 AM | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | Hey guys, So I'm replacing my heater core on my 1960 C10 with the deluxe heater. I have the new core I bought from Napa that they say is for this year. Well first off It doesn't have a mounting place for the heat valve. just the 3/4 and 5/8 tubes coming out. I had to by a inline valve. 2nd the inlet and outlet tubes are in different places. They go above the core.( I know the oulet is on the top but my original inlet tube is on the side.) I tried to go to different stores to find a different core. No luck they are all the same style. So my question is Has anyone had this problem? Do I have to modify the top plate that hold the core? can I heat and try to bend the tubes? Is there a place that will sell a core with the inlet tube and valve that's on the side? HELP!
Thanks,as always -Danny
1960 C-10 Stepside,Longbox 235,4spd 3.90 diff.
#77484 05/12/2007 12:35 AM | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Danny:
The factory heater core for the '64-'66 Chevy trucks has the inlet and outlet on the top of the heater core and they come out on the passenger side of the heater box through the top of the heater box cover. The heater core is held in place by two U-shaped strapes that are held in place by two 1/4" sheet metal screws. The heater core/heater box may be slightly different on the '60-'63.
I hope this helps.
Tony | | |
#77485 05/12/2007 4:25 AM | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | Hi Danny.I'm rstoring a 1960 LB stepside as well.Can you tell me what the differance is between the regular heater and the delux heater.
Thanks, Gary | | |
#77486 05/12/2007 6:32 AM | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The Thrift Air heater and the Deluxe heater have different dash controls, different underdash diffuser box, different control cables and different fan motor speeds.
The Thrift Air heater is a two speed fan with a single pull knob on the dash. The defrost must be engaged by shifting the lever on the underdash diffuser box. The Deluxe Air heater/defroster has four levers ('60-'63) and three knobs ('64-'66) on the dash. The heater, fan speed and defroster are controlled at the dash controller.
I hope this helps.
Tony | | |
#77487 05/12/2007 2:40 PM | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | In my '60 I've got 2 levers in the middle.The outside 2 slots are blocked off from behind.One is the fan and one is defrost.Is this the Delux version?
Danny,sorry for robbing your thread just trying to get this figured out.
Thanks, Gary | | |
#77488 05/12/2007 11:34 PM | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | I tell you guys, this heater core is impossible to find! the closet thing I found was a used one from a 59 pontiac and it was just 2in longer then mine! so close! Why don't they make one with the valve that bolts to the side???
#77489 05/12/2007 11:49 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | take it to a rad shop and have it recored
Bill | | |
#77490 05/13/2007 11:38 PM | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | Danny, This is a common problem in cars too. Your vehicle has the standard heater & the only repl. cores made are the deluxe models. NO problem....Where the cable operated water valve would normally go in the box, leave it out. One less future in-cab leak. With that extra space in the box, you can solve your wrong-position plumbing problem. Get some 1/2" copper fittings & a stick of hard Type L tube at your plumbing supply & make up a manifold adaptor to get it where you want it & thru the firewall. The tube O.D. will be 5/8", just right for your hoses. Run a bead of solder near the tube end to guarantee the hose & clamp can't slide off. Get a inner-fender mount type of shut-off valve, when that starts leaking someday, you'll be happy it's not inside the heater box. If you wish, you can also at this time upgrade from the single-speed to a three sp. blower. Get about any resister off one that mounts inside the heater box/duct outlet & put it in yours. Get a three sp. blower motor & squirrel cage that'll fit in your box, many are similar. Repl. your existing on/off switch with a three-pos. one. Doug | | |
#77491 05/14/2007 6:56 AM | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | APACHEMANSLIM60 Look your truck up here there is two options for your heater core recirculation heater or fresh air, one is on top the other on the side. http://www.rockauto.com/ Darrell | | |
#77492 05/14/2007 2:12 PM | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | There's a guy who will rebuild your old heater control valve for ~$80: http://heatercontrolvalve.com/ Bill | | |
#77493 05/14/2007 2:16 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | If you are not real worried about being stone stock you could use 64-66 heater, cores are readily available. | | |
#77494 05/14/2007 3:04 PM | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Did you look at the ad in the Truck Parts for Sale forum? Bill | | |
#77495 05/15/2007 12:26 AM | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | I got it, I had mine recored, thanks all for your help!
