1 members (mason86),
63
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77468 05/11/2007 4:13 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I am going this weekend to the local pick-a-part to look for a drive shaft for my T5 swap. Now I know several people that have done this, have used a drive shaft out of a Chevy Astro Van. What other options do I have just incase I can't find an Astro Van? Thanks George | | |
#77469 05/11/2007 6:41 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Hi George,
I used the driveshaft out of an 85 S10 shortbed pickup. Had to cut it down 1-1/4". Later on decided to re-center my 54 AD rear end in the wheel well.....needed 1-1/4"!!!!!
I am running a 235, correctly mounted, an 85 T5 and a Camaro diff and would suggest that you try the S10 one piece short bed drive shaft. Didn't have to change the rear universal.....bolted right up. Not positive, but I think any of the short bed S10's up to 89 (all mechanical speedo's) would be the same. Hope this helps.
Dave | | |
