2 members (Wheelie, 78buckshot), 78 guests, and 1 robot.
Topics128,050
Posts1,055,643
#77468 05/11/2007 4:13 PM
I am going this weekend to the local pick-a-part to look for a drive shaft for my T5 swap. Now I know several people that have done this, have used a drive shaft out of a Chevy Astro Van. What other options do I have just incase I can't find an Astro Van?
George
#77469 05/11/2007 6:41 PM
Hi George,
I used the driveshaft out of an 85 S10 shortbed pickup. Had to cut it down 1-1/4". Later on decided to re-center my 54 AD rear end in the wheel well.....needed 1-1/4"!!!!!
I am running a 235, correctly mounted, an 85 T5 and a Camaro diff and would suggest that you try the S10 one piece short bed drive shaft. Didn't have to change the rear universal.....bolted right up. Not positive, but I think any of the short bed S10's up to 89 (all mechanical speedo's) would be the same. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
