2 members (Otto Skorzeny, Charles in CA), 79 guests, and 0 robots.
Topics128,051
Posts1,055,764
#77464 05/11/2007 4:08 PM
Hello
I am looking for internal parts for a 4 speed trans in my 1949 3100. Trans is good shape but need 3/4 syncronizer. It grinds if I shift it to fast. If I shift it slow or double clutch it's ok. Does anyone know the trans model???
TIGHT IS TIGHT,TOO TIGHT IS BUSTED
#77465 05/11/2007 4:12 PM
Bill,
I'm going to guess that your transmission is a SM-420 and that parts are readily available. I have enclosed a link to a outfit that has good info and it appears all the parts you would need for a rebuild. Good luck! smile
http://www.novak-adapt.com/catalog/sm420_parts.htm
Stuart
#77466 05/11/2007 4:14 PM
That would be the SM420. Check over on the Links page, there's a couple of sites with info on that tranny. And if you don't have a shop manual, check out the Online Chevy Manual site. I think that there is a '49 manual on there, if not, any of the later manuals would have info on the trans as well, as it was used up to '66.
I can relate to the syncro problem you're having. A guy I ran around with in my youth had a '49 1 ton 4 speed. It did the same thing.
Bill Burmeister
#77467 05/11/2007 8:49 PM
The Novak site that Bill gave is a good place to look. Also there has been alot of talk about the SM420 in the Bigbolts.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
