0 members (), 82 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
I just spent hours installing the new windshield glass, gasket, and original garnish molding. The glass phase was fairly uneventful but the molding was a nightmare. After lubing the gasket, I finally had to resort to large C-clamps and wood block scraps to crank the outer corners of the molding into place. I can live with the final product but it didn't meet my expectations appearancewise. The rubber gasket ended up mashed and twisted somewhat in the corners. I would appreciate suggestions on making this project go smoother on my next truck. Thanks!
1946 Chevy pickup, 1948 Chevy suburban, 1950 Chevy pickup, 1952 GMC pickup, 1957 Chevy pickup, 1939 Chevy pickup
Pinetree,did you fit the glass and rubber to the truck and then try to install the chromes?
If so,that's where you went wrong.
The glass,rubber and trims are designed to be installed as a complete assembly.
I would do a 'how to' tech tip for the forum if only I could find a good set of original trims myself!
More pix on Flickr.
Yes, That's what I did wrong. Although I must say that roping in the glass in the first place was a little tight. With the benefit of 20/20 hindsight, windshield glass even 1/8" smaller would have gone in a lot easier with chrome trim. Thanks for the feedback!
I decided that I couldn't live with the half-assed appearance of this job, so I cut out the sealant smeared gasket and started over. I took the glass back to the glass dealer to have him grind 1/8" off of each edge. He told me that he has seen that the cheap Chinese gaskets sold by many catalog companies are too thick. He said that U.S.-made gaskets by Steele, Danchuk, etc. are pricier but fit properly. He recommended using silicone spray as an installation lubricant and discouraged the use of extra sealant unless water leakage developed in use. Armed with this adsditional info, I'll try again next week after I've accumulated all the necessary supplies. Apparently, new techniques and materials have superceded my 60+ year old shop manual.
I agree with your glass guy regarding the rubber seal.
From what I've read Steele seems to be the one of choice.
I'll need to get one myself as i have a cheap ROC one and in one word it is cr*p!
My own truck hasn't even been on the road yet and the rubber's showing signs of ageing/cracking already!
If anything I've found the glass from aftermarket suppliers seems to be too small,or badly shaped.
Personally I prefer to use plain old glass cleaner to lubricate the rubber during the install as I'm not a huge fan of silcon based products.
It's neutral,dries without residue,and doesn't/wont cause any additional painting issues in the future. JMO.
More pix on Flickr.
Perhaps the water repellant properties of the silicone are what allows the omission of sealant caulking. Dave
Success! The smaller glass panes made a difference. On to the next challenge.
I love it when a plan comes together......
Good you got 'er done Pinetree. So where's the pics? wink
More pix on Flickr.
Thanks for the support jockbolter50. In all honesty, I do not yet own a digital camera. By choice, I live as much as possible in the middle of the last century. Stovebolt being an exception.
I'm a bit like you as well Pinetree, I admit though,I have made a few concessions to modern living!
Still hate cell phones though........ grin
More pix on Flickr.
