1 members (baldeagle),
38
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 1 New Guy | | New Guy Joined: Aug 2011 Posts: 1 | Hello. My name is Trevor. Im a Assistant Manager at a Auto Body shop. I have been into old cars and trucks for several years now. I just bought a Stock running and driving 51 Chev Fleetline. I'm converting it over to 12 volts. The wires in the car are all cracked. This may be a good place to get some questions answered about that and more! Fleetline51 Trevor | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | welcome man, and nice choice on auto. my wife has a 50 fleetline. you will definitely like the 12volt conversion better. replace all the wires that are exposed of course, but the ones that are still insulated you can use w/ 12 volt. 6v systems carry more amperage, so the wires will accept the 12v setup. also, be aware of the small things electrical like gas gauge. your gauges will be 6v, so you will need a voltage reducer so they will work on a 12v system. or you can replace that stuff too. good luck man. there are alot of knowledgeable folks here that can help you out. -DVZ | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome Trevor, I also converted to 12 volts, one of the only changes I made on my truck. We have a number of different forums, check out the electrical forum if you need help with the wiring. Good luck, Leo | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | welcome Trev, I am sure you will enjoy the ride here. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
