9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible),
125
0
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | I need help with my 46 ½ ton OE Huck brake reassembly. When assembling a new E-brake cable assembly to a backing plate: is the OE retainer installed onto the new cable, sandwiching the cable between the new and OE retainer; then threading the spring end of the cable into the backing plate (outside to in) and bolting the sandwiched cable end to the backing plate placing a gasket between? Or, does the cable thread through the backing plate (inside to outside) and the new and old retainers sandwich the backing plate, a gasket, and cable? Pictures of the two options are at the link. http://www.flickr.com/photos/dodsonbrett/sets/72157627378295525/Any help is appreciated | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Got a picture from fellow bolter Dave and it shows option 1 was the answer. If interested I posted the photo along with the options. Cavebull | | |
