1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
Replacing the wheel studs on my '60 1/2 ton.Got the front done but can't seem to get the rear ones in.They stop about an 1/8 of inch before they seat.I'm using an air impact gun.Have tried using a breakover with a cheater but just busted the stud.Anybody got a solution?
Current project . . . 1960 LB stepide Chevy
Riding in the Passing Lane
It shouldnt be a problem. You could have the wrong studs. They usually pull in with a nut & stack of washers. Put some anti sieze or grease on them. You might grind the shoulder down a little.
1972 Chevy c10 Cheyenne Super
I've checked with the local automotive store and they tell me they're the right ones this time.First time they did give my the wrong ones tho.
A hydraulic press works great.
Or sometimes a "ball joint press" the big C-clamp looking tool, also used for U-joints, will work.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
My dad has a press but I'm trying to keep from splitting the axel.
Stick them in the freezer a coupla hours & put them in one at a time, leaving the others to stay cold.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I just used the nut and stack of washers process. Worked fine on my eight lug hubs. You do have to watch how soon you handle the nut though...mine got a bit warm.
One trick was to line up the ridges on the stud with the slots already worked into the hub.
1965 Chevy C-30 1-Ton
"Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching."
Thanks for all the tips guys.I'm going to give the freezer thing a try tomorrow.I've replaced many a lug bolts in my day and never had a problem like this before.Wish now I hadn't taken the old bolts out.Wasn't anything wrong with them I was just wanting new ones put in.Live and learn I guess.
H Online: Content
Use a deepwell socket or an old piston pin over the thread, and press the stud into the axle flange with a big C clamp. Get as much tension as you can on the clamp, then smack the end of the clamp screw with a BFH. The stud will move a little. Then tighten the clamp and smack it with the hammer again. The combination of clamping force and hammer blows will seat the stud without overstressing the thread by using the nut/washer approach. If you stretch the thread with too much torque, you're wasting your time installing a new stud.
