7 members (cmayna, dt235sd, baldeagle, 1955 1 Series, NJC, 2 invisible), 93 guests, and 6 robots.
Topics128,016
Posts1,055,337
Members48,419
#774298 08/23/2011 5:39 PM
Hello.
My name is Trevor. Im a Assistant Manager at a Auto Body shop. I have been into old cars and trucks for several years now.
I just bought a Stock running and driving 51 Chev Fleetline. I'm converting it over to 12 volts. The wires in the car are all cracked. This may be a good place to get some questions answered about that and more!
Fleetline51
Trevor
Fleetline51 #774334 08/23/2011 7:03 PM
welcome man, and nice choice on auto. my wife has a 50 fleetline. you will definitely like the 12volt conversion better. replace all the wires that are exposed of course, but the ones that are still insulated you can use w/ 12 volt. 6v systems carry more amperage, so the wires will accept the 12v setup. also, be aware of the small things electrical like gas gauge. your gauges will be 6v, so you will need a voltage reducer so they will work on a 12v system. or you can replace that stuff too. good luck man. there are alot of knowledgeable folks here that can help you out. -DVZ
dvzdeathtrap #774401 08/23/2011 10:27 PM
Leo Offline
Moderator
Moderator
Welcome Trevor, I also converted to 12 volts, one of the only changes I made on my truck. We have a number of different forums, check out the electrical forum if you need help with the wiring. Good luck, Leo
Leo #774403 08/23/2011 10:33 PM
welcome Trev, I am sure you will enjoy the ride here.
Redryder pix
My Hotrod
