2 members (VicZ, klhansen),
118
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#7742 11/26/2003 10:27 PM | Joined: Nov 2003 Posts: 1 Junior Member | | Junior Member Joined: Nov 2003 Posts: 1 | I just bought a 54-55 gmc straight 6 250 truck (no bed) in time to store it for the winter. I have driven it VERY little to this point. On my way to the storage garage (8 miles) the truck began to lurch, jerk and I had very little power. It did fine for 7 + miles, inches from my destination. The engine sounded like I was flooring the accelerator while in 2nd gear - - strained. There was oil near the two spark plugs closest to the firewall, oil on the ground 4-6" diameter. Within minutes, it started up fine, and I got to the storage garage. I am very green to this truck and the older ones in general. Where do I start? Rear seal? A choke issue? (it was pulled half out on a 55 degree day)? Ideas of where to start? Thanks, zan | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | you should drive the truck on the choke for as little as possible. I usually don't leave the driveway until I can push the choke all the way back in.
It could be as simple as that.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | There's a SLIGHT possibility that coolant may be entering 1 or more cylinders while running, causing resistance during the compression stroke, making your engine "strain". Not a common occurance, but you never know.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
#7745 12/02/2003 11:00 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | When was the truck last driven? You could have an ignition problem. You could have a coil that is overheating, for example.
