7 members (Otto Skorzeny, MickeyP, Brian Moore, Gdads51, Wayne67vert, Bill Hanlon, 1 invisible),
49
Mod | | | Forums66 Topics128,049 Posts1,055,653 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | On the '55 Second Series 235 which oil lines go where on the optional oil filter? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There was a variety of accessory oil filters. If you have the GM AC filter canister, the outflow is at the bottom and the inflow is at the upper side. Here are the locations of the ports on the block. | | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | I have two filter canisters at home to choose from. They are both orange. I'm not sure if that actually means they are true Fram canisters or not. Is the 'Inflow' and 'Outflow' always on the same location on the canister? | | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | Hey, I just thought to check the Tech Section. It explains some things as well. Thanks!! | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Is the 'Inflow' and 'Outflow' always on the same location on the canister? Mine has the return at the bottom.
