10 members (1955 1 Series, Otto Skorzeny, JW51, Greg_H, Bill Hanlon, Ponchogl, Gdads51, Peggy M, TrknGMC, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,689
#774072 08/22/2011 10:58 PM
On the '55 Second Series 235 which oil lines go where on the optional oil filter?
mrcaddy #774076 08/22/2011 11:05 PM
There was a variety of accessory oil filters. If you have the GM AC filter canister, the outflow is at the bottom and the inflow is at the upper side. Here are the locations of the ports on the block.
I have two filter canisters at home to choose from. They are both orange. I'm not sure if that actually means they are true Fram canisters or not. Is the 'Inflow' and 'Outflow' always on the same location on the canister?
Hey, I just thought to check the Tech Section. It explains some things as well. Thanks!!
Ex Hall Monitor
Ex Hall Monitor
Mine has the return at the bottom.
